Tankless HW Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2013, 07:57 PM   #1
justinramani's Avatar
Tankless HW Heater
I am about to install a new tankless hot water heater and I have a few questions. The tankless heater I am installing is the Ecoboost 27. This particular unit requires 3 x 40 Amp DP breakers. It also requires that each run be done with 8 - 2 wire. Since the current WH is about 40 feet from my service panel I would need to run approx 150+ feet of wire. In order to avoid this I am contemplating relocating the tankless unit so that it is closer to the electrical panel. If I move the tankless to a new location and add approx 40 feet of pex tubing to my hot water line will this cause me to have to wait longer to get hot water to my bathrooms? The unit takes approx 45 - 60 seconds to deliver hot water even in the most ideal situation. would 45-60 seconds be long enough for the water to circulate through the additional piping? My next question is in regards to the existing expansion tank. Can I simple leave it alone? My understanding is that it wont do any harm if left with a tankless set up. What about if I move the unit 40 feet away? Can I still leave the expanision tank where it is?
Sent from my iPad using DIY Forum
justinramani is offline   Reply With Quote
Old 05-16-2013, 08:54 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
I recommend you consult an electrician before adding that many additional amps to your system, i see homeowners with all kinds of issues with tank-less electric water heaters, mainly electrical, don't expect savings on your power bill. i would never recommend tank less unless its gas,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-16-2013, 09:55 PM   #3
Rewards Points: 2,106
I second that thought especially in the colder areas of the nation.
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 12:39 AM
Tankless Water Heater MJI22 Plumbing 5 08-26-2012 12:43 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
tankless water heater brewmastr Plumbing 7 01-09-2011 09:57 PM
tankless or tanked water heater? wombosi HVAC 5 02-11-2009 07:34 AM
