Tankless Hot Water Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2009, 07:05 PM   #1
I have had a whole house tankless hot water heater for a couple of years that is probably working as designed: once the water heats up and travels to the faucet, it will keep providing hot water forever. Unfortunately, one of the longest runs is to the kitchen sink and it's a pain waiting for the water to heat up when washing dishes. Can I put a small tankless unit under the sink? If so would I just cap off the hot feed and branch off the cold feed through the new tankless to form a new hot feed for that one sink? (I wouldn't want to come off the hot feed because that would turn on the whole house unit, right?) If that won't work, is there a better solution? Thanks.
geoallen is offline   Reply With Quote
Old 12-25-2009, 09:33 PM   #2
Rewards Points: 1,016
You can do a local demand unit as you describe. They also make demand units that are designed to be used in conjunction with the whole house unit. When working in conjunction, the local unit heats water only until it senses hot water arriving from the whole house unit.
Old 12-25-2009, 09:38 PM   #3
Thanks. I think the second option is what I need. Do you know any manufacturers where I could research the available units?
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Tankless Water Heater Issue fjacky Plumbing 12 01-21-2011 07:28 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
