Old 12-03-2009, 07:28 PM   #1
tankless hot water heaters
OK, first time installing a tankless on a house, How do I know what I really need, someone recommend a takagi-JR. The house will have 2 1\2 baths, one with a double bowl sink, and a gas range. Can this heater carry all of that. Looked It up and some of the specs have me asking questions. First, what are BTU's second what is W.C. you guys don't laugh at me, still young and haven't really messed with gas before thanks.
Toolmaster is offline   Reply With Quote
Old 12-04-2009, 09:29 AM   #2
While I always promote DIY projects, not all are good choices for those without experience. This is especially true with gas lines. You need to know how to size gas lines for volume so you don't "starve" the fixure using the gas. Anther problem is any warranty for the Tankless heater may be voided if not installed by a licenced person. BTU's are a measure of heat produced and WC is "normally" a Water Closet (toilet). Since i cannot see the instructions, I am at a loss to figure out what you need. This sounds like a new house or major remodel and may require a permit.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-04-2009, 09:34 AM   #3
WC should be water column. A measure of pressure. This definitely not a starter project. I think you should sub this one out. I hope this is for your own house and your not even thinking about doing this in a customer's house.
jerryh3 is offline   Reply With Quote
Old 12-04-2009, 11:01 AM   #4
We installed a gas tankless heater in the log house we're building. Most manufacturer's websites have information on how to pick the right size. Based on information I found there, I picked the size and installed the unit myself. I had the gas company do the gas line.
One other thing to consider carefully is how the heater will be vented. Not only for safety, but also because the vent piping is quite expensive.
md2lgyk is online now   Reply With Quote
Old 12-04-2009, 11:30 AM   #5
An old Tradesmen
As earlier. WC is water column. And is generally referring to the gas pressure to the unit and manifold.
BTU is British Thermal Unit. Its a measurement of heat.
Old 12-04-2009, 12:24 PM   #6
It was a dark and stormy
Yoyizit's Avatar
50 to 200 gallons per person per day, with 120 being average and with ~half of that being 120F hot water.
It takes 8.3 BTU to raise one gallon of water 1F.
Your incoming water is ~50F.
BTUs measure energy, and the rate of consuming energy = power.
100,000 BTUs = 29.3 kwh, or 100,000 BTUs per hour = 29.3 kw.
Old 12-04-2009, 12:26 PM   #7
Originally Posted by Yoyizit View Post
~100 gallons per person per day, with half of that being 120F hot water.
Is all of that assuming 100% efficiency?
Old 12-04-2009, 12:28 PM   #8
Yoyizit's Avatar
It comes from here
http://www.onlineconversion.com/
but I guess tankless units run at near 100% efficiency.
Old 12-04-2009, 09:41 PM   #9
WC also means "water closet" in Europe. In other words, a bathroom.
I have a tankless heater, but I don't recommend it.
If you don't understand how to install it, then it's definitely not a DIY project. In my case they needed to put in a new vent/chimney, and a new gas line. It was a big project.
It doesn't work as well as a water heater should, and it uses a lot more gas than I expected.
pyper is offline   Reply With Quote
Old 12-05-2009, 06:42 AM   #10
An old Tradesmen
It comes from here
Electric are 100%. But you can get 80% efficient tankless in gas fired units.
Old 12-05-2009, 06:59 AM   #11
Nothing is 100% efficient. But maybe it can round up.
To me, it doesn't matter how "efficient" they are as much as it matters how much energy they use in the course of a year. A standard water heater has a 40,000 BTU burner that runs 15 to 30 minutes a day. A tankless heater has a 250,000 BTU burner that runs whenever you turn the hot water on.
Old 12-05-2009, 07:08 AM   #12
An old Tradesmen
There is 3.413 BTUs to a watt.
So for every watt an electric heater consumes. You get 3.413 BTUs of heat.
Old 12-05-2009, 07:33 AM   #13
There's a difference between the physical efficiency of the heating element and efficiently using the heat produced.
Old 12-05-2009, 07:40 AM   #14
An old Tradesmen
All the heat the element produces. Will be absorbed by the water(talking electric water heaters, or boilers).
On electric heating elements used to heat air. As long as the element is not allowed to get hot enough to glow. You still get 100% of the heat.
Now if your talking about delivering that heat to an area. That is distribution efficiency. And is another topic itself.
Old 12-05-2009, 12:34 PM   #15
Yoyizit's Avatar
I don't like 'em.
The ones in Germany were clicking all the time trying to keep up, and in three weeks I never got to take a shower without at least some cold water dumping on me.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Tankless water heater to pre-heat incoming water matthet Plumbing 28 12-20-2011 09:11 AM
Electric tankless water heaters anyone? brokenhammer Plumbing 3 09-17-2009 10:20 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
