Tankless Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2010, 10:39 PM   #1
Rewards Points: 1,088
I used to hear that tankless hot water heaters can't provide the same amount of hot water that a tank can provide for larger homes (e.g 4 BR, 3.5 BA). Has that now changed?
Here's an example of a Rinnai tankless model that supposedly can put out the equivalent of six 40 gal hot water heaters in one hour.
Also, they supposedly are good for 25 years.
http://www.dontdig.com/tanklessheating.php?animation=1
How much would one cost installed?
handy man88 is offline   Reply With Quote
Old 03-18-2010, 09:24 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They are based on a rate of flow at a certain delta T which depends on your incoming water temperature. You will essentially be feeding an entire house through a 1/2" heat exchanger coil.
Journeyman Plumber
Old 03-19-2010, 09:00 PM   #3
I'll bet you are looking at over $3000 installed. I put one in my self, it will supply 2 things using water at once. I bought a refurb unit and it was almost $800 + chimney (stainless steel) and electrical. I spent $1500 as a DIY project. You can buy a lot of water heaters for $3000...
Having said that I love having an endless supply of hot water and I would do it again.
UFoPilot is offline   Reply With Quote
Old 03-19-2010, 09:27 PM   #4
How long will it take you to make up for the cost savings in gas?
Old 03-19-2010, 10:21 PM   #5
I probably save about $500 a year in propane. It will pay for itself but it will take a long time.
Old 03-20-2010, 05:38 AM   #6
An old Tradesmen
Rewards Points: 6,914
Gas tankless water heaters will supply continuous hot water as long as you don't exceed their GPM flow rate.
How much you will save depends on how much your hot water demand is.
Cold water going into Tankless Water Heater TrustedHandyman Plumbing 1 01-07-2010 01:27 PM
Tankless Water Heater Problem Thalweg Plumbing 4 12-10-2009 12:18 PM
Tankless water heater proper pipe size? gante Plumbing 5 04-06-2009 02:28 PM
tankless water heater maintenance ericadami Plumbing 8 11-24-2008 01:42 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 08:49 AM
