Tankless Crapper ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2013, 09:04 PM   #1
Rewards Points: 236
tankless crapper ?
i am watching HGTV. they showed a bathroom that had just this in it. i could really use one of these, if they are not expensive.
how much are they ?
are there any problems with them ?
anything else to know ?
thanx
Fix'n it is offline   Reply With Quote
Old 12-18-2013, 04:46 AM   #2
DIY staff
Rewards Points: 7,174
You need a large water pipe to feed the toilet--1" in most cases----the toilets are not terribly expensive---the Sloan flush valves will set you back as much as a cheap toilet,however.
Call a local plumbing supply house----do not attempt this with 1/2" feed lines---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Javiles (12-22-2013), plummen (12-18-2013)
Old 12-18-2013, 11:44 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Do you have a link?
Just curious, is it really tankless, or is it a hidden or wall-hung toilet?
Here's a link, if the mods don't mind.
http://www.thisoldhouse.com/toh/askt...204978,00.html
Old 12-18-2013, 06:56 PM   #4
Rewards Points: 3,788
You need to check your supply. You can do it with 1/2 inch if everything is right.
This from Dexterton toilets:
Required water pressure:
0.15 MPa (21.33 PSI) ~ 0.75 MPa (106.67 PSI)
Water volume flow rate:
Use the following method to determine the water volume flow rate.
1. Prepare a bucket.
2. Let water out for 10 seconds to check the flow.
3. When water supply of 5.5 L or up is reached within 10 seconds (8.72 gallons per minute), then required water volume is secured.
NOTE : The most ideal diameter of the water supply pipe is 1 inch.
A 1/2 inch water supply pipe can be used provided that the required water volume (5.5L in 10 seconds) is acquired.
Bob Sanders is online now   Reply With Quote
Old 12-18-2013, 07:53 PM   #5
Rewards Points: 236
ok, i guess i can not have one then. i only have 3/4 into the house, and it ain't flowin 8+ gl a min.
the reason i am asking . my 1/2 bath ( a crapper and a small sink) is cramped. if i could get even just a few more inch's of legroom . i am planning to move the wall a little. but if i didn't have to .... that would get nice. any ideas ?
Old 12-18-2013, 08:56 PM   #6
RV sink and toilet?
http://www.ebay.com/itm/RV-Marine-Ca...-/380685657704
http://www.amazon.com/gp/product/B00...productDetails
In fact I just stuck an RV toilet in up at the cabin. Works great.
Old 12-18-2013, 09:44 PM   #7
Rewards Points: 236
thanx. i only need more sitting leg room. the sink spacing is fine.
Old 12-18-2013, 11:07 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 682
The tankless toilet that works with a 1" flushvalve does not take less floor space- well maybe 2"- but your water pipe sizing will need an upgrade to meet water fixture unit code requirements
There are wall hung residential toilets as well...
Old 12-19-2013, 08:19 PM   #9
Rewards Points: 236
ok, well. the toilet that i saw on hdtv. it like a regular crapper. but, right behind the seat hinge, it was cut off verticaly.
Old 12-22-2013, 10:40 AM   #10
Rewards Points: 636
in wall toilet tank is my guess
https://www.google.com/search?q=in+w...w=1600&bih=774
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Tankless - Black Soot Problem BillGrayslake General DIY Discussions 0 04-13-2013 01:02 PM
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 12:21 PM
Make the jump to tankless? Recommendations? acerunner Plumbing 8 09-26-2010 09:27 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Tankless hot water heater??? psychocandy Plumbing 1 03-22-2007 10:41 PM
