Tankless Causing Water Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2012, 10:15 PM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
It is a well known fact that tankless causes pressure drop the higher you flow water through it. We have two Rinnai 75Lsi heaters, originally plumbed together in a manifold, then with a manifold with a pressure activated valve.
1. With pressure valve low flow faucets cut water heater on, but get loud water hammer from Kohler shower mixing valve during high flow. Called Kohler and they said any difference between hot and cold greater than 5 psi will cause hammer.
2. Took pressure valve out, no water hammer but low flow faucets can't trigger heater. Each single unit requires 0.4 gpm working together using EZ connect this must be 0.8 gpm?
Any solutions to get both situations to work?
Chris
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 07-26-2012, 09:46 PM   #2
Still going...
ChrisDIY's Avatar
Rewards Points: 508
With some experimentation I can stop hammering by turning on another faucet to force second unit to kick on, then turn it off and hammering stops. :-(
Sent from my Galaxy Tab using DIY Chatroom
--Chris the DIY Guy
Hammer Arrestor Tankless Water Heater brainstewn Plumbing 0 06-15-2012 10:53 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Tankless hot water sporatic until........ Ronin33 HVAC 15 06-05-2007 03:12 AM
water hammer question seanstoner Plumbing 7 04-10-2006 04:28 PM
