Tank On Toilet Will Not Refill - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2013, 03:01 PM   #1
Exclamation
Tank on Toilet will not refill
My tank on my toilet will not refill. I have replaced the fill valvue and it was working but once the cold weather hit now it will not refill. It has been three days now. I have tried putting hot water in the tank and it might work for one flush but thats all. I have tried blowing a hair dryer on the water line into the toilet as well. No other lines in my house are like this, they all are working fine. It is just my upstairs toilet. Any ideas on what could be the problem? Please help!
Jenn
smileyone07 is offline   Reply With Quote
Old 01-03-2013, 03:35 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... My guess is the water feed line is Freezin' up, Somewhere...
Hard to say just where,... does the line run through the outside wall,..??
Old 01-03-2013, 03:52 PM   #3
don't use hot water. toilet bowls have been known to shatter when the hot water hits the cold bowl.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
HELP!! Toilet leaking from sides of tank when flushed. teamcampreder Plumbing 17 08-01-2011 10:26 AM
toilet tank intermittently would not fill handyman_wanabe Plumbing 4 07-07-2011 09:14 PM
Toilet tank leans against the wall, leaks MBarker Plumbing 3 10-04-2010 08:28 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
