Old 11-15-2005, 07:27 PM   #16
Contractor
tank less water heaters
Dustin, always start with end use. Plan on maximum usage/ min. pressure.
In your case, I would allow for about 9 GPM @ 45 PSI of hot water unless you are on a well, then figure at 35 PSI. You can add quite a bit more when your kids become teenagers.
Teetorbilt is offline   Reply With Quote
Old 11-15-2005, 10:48 PM   #17
Contractor
KenTheHandyMan's Avatar
I looked into the tankless deal recently because my water heater had rusted out and was costing $55/month just in gas!
The tankless units I saw cost twice as much as a standard tank heater and would replace a 40gal tank unit, but they all said 'one major application at a time', meaning 1 shower going...1 load of laundry going...or 1 dishwasher going. That would never happen in my house (7 children and a wife that loves the smell of fresh laundry).
I do want to comment on the 'keep your house the same temperature' myth. Case studies show that in fact, it is more economical to kick the furnace on (or a/c) when you get home from work and kick it off when nobody's home. It only takes 20 minutes to get things back to the preferred temperature. Granted, if you live in a cold weather climate like I do, you should leave it set to well above freezing.
I must be a scrooge though because I haven't so much as fired my furnace up except to make sure it was working and ready for winter. I've got a couple of electric ceramics, a fireplace, and a kerosene heater that I've made use of on some real cold mornings, but if it's 45 outside, the house stays around 60-65 with the fireplace going and all those little ones running around. Plus my office has 2 computers in it so it's always warm in there...were we talking about water heaters? LOL
On the outdoor furnace, I installed one for a friend and they are very nice. Heats the baseboard heaters well. Heats the water in the hot water heater so hot that a mixer must be installed to mix cold with the hot or you will burn yourself. He only uses that feature in the fall/winter though because he shuts the furnace off in spring. I'd get one but I live in the city.
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 07:52 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
