-   -   Tank-to-bowl gasket help (http://www.diychatroom.com/f7/tank-bowl-gasket-help-90823/)
n0c7 12-30-2010 08:10 PM
Yesterday I rebuilt two of my toilets with Moen kits. Everything is functioning fine however this morning I noticed that there was water slowly sweating from the TOP of tank-to-bowl gasket when I checked with a flashlight. The bottom of the gasket that meets the bowl is fine.
I originally hand tightened the large white plastic nut that holds the flapper and drain tube assembly down. I took the tank off and tightened this white plastic nut as tight as I could safely go without cracking the tank(cannot be untightened by hand any longer).
Since I had the tank off I decided to fill it up in the bath tub without the tank-to-bowl gasket on. Water seeps out around the nut threads as there is nothing sealing the threads. The instructions specifically say not to seal these threads with Teflon tape of joint compound.
I put everything back together and the only difference is that the nut is slightly tighter. I don't see any leaks yet, but if I poke the tank-to-bowl gasket with a q-tip water starts to come out as this gasket is the only thing holding the water in. Is this the purpose of these gaskets? I also tightened the tank wingnuts as tight as I could by hand. Is this too tight?
Homerepairguy 12-31-2010 02:06 AM
Do you have rubber or fiber washers between the bolt heads and the tank, "inside" of the tank? That's where the water seal occurs.
n0c7 12-31-2010 10:05 AM
Rubber washers. The leak is occurring at the flapper gasket.
SuperPlumberGuy 12-31-2010 11:47 AM
The tank-to-bowl gasket is not the issue. There should be a tapered gasket between the flush valve and the tank (inside the tank) I would bet that is where your problem is :yes:
n0c7 12-31-2010 02:01 PM
You're right, that's where it's leaking from. I had purchased a Moen rebuild kit and was having nothing but issues including this gasket. I went out and bought a Fluidmaster kit which has a much nicer gasket and for $3 more is just a nicer set of parts overall. I had to use a wrench to tighten the drain tube assembly to get the new Fluidmaster gasket to stop leaking whereas even at almost cracking point the Moen gasket still leaked. I have the tank off the bowl sitting full of water in the bathtub as a test right now to see if any of the seals leak. Will report back.
Michael Thomas 12-31-2010 05:48 PM
An easy extra step which has solved "mystery" tank leaks for me in the past: if the interior bottom of the tank is not perfectly smooth,
http://www.terrylove.com/wc/toto/drake_sand_bolt3.jpg
take a bit of emery paper and smooth the bottom around the bolt holes, and if you are replacing it, the valve.
n0c7 01-02-2011 06:05 PM
That's where it was, thanks!
Originally Posted by Michael Thomas (Post 559949)
An easy extra step which has solved "mystery" tank leaks for me in the past: if the interior bottom of the tank is not perfectly smooth, take a bit of emery paper and smooth the bottom around the bolt holes, and if you are replacing it, the valve.
Worked like a charm, made the next tank rebuild much easier!
