Old 06-01-2008, 09:16 PM   #1
Tank bolts dripping!
Old bolts on the toilet were rusted out so i replaced with brass. Cleaned tank very throughly and tighened new bolts fairly hard to the point where if i turn it a little more i break tank? Any suggestions, thicker washers, thinner, bigger smaller??? I dunno. Thru-bolt holes on tank are no chipped from removal of old one. What else can i do?
anc001 is offline   Reply With Quote
Old 06-01-2008, 09:26 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
remove the bolts and use a little sandcloth on the bolt holes. Use a little pipe dope on the washers when reinstalling. works for me all the time
JDC is offline   Reply With Quote
Old 06-02-2008, 12:17 AM   #3
Inside the tank, where it matters, use just the rubber washers on the tank bolts, and throw the metal ones away. I always hand tighten them as much as possible.
darsunt is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Relocating Oil Tank jbboater HVAC 2 03-23-2008 08:50 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
