Taking Out Disposal - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2006, 11:22 AM   #1
taking out disposal
I am putting now counter tops in and need to take my sink out. The show stopper is taking the disposal out. I am stuck. If any of you can suggest me how to take disposal out will be helpful. Thanks
siyer is offline   Reply With Quote
Old 12-10-2006, 11:31 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Do you know what the brand is?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-10-2006, 02:11 PM   #3
Most disposers are installed the same way. Turn OFF the breaker to the power circuit (unless it is a plug-in model, if so, unplug it) and disconnect the wiring. Disconnect the drain piping from the disposer by unscrewing the nut holding the pipe to the unit. At this time, if your water supplies are disconnected, you can remove the whole sink, disposer and all. Or, you can also remove the unit from the sink drain basket by turning the connecting nut counter-clockwise. Be careful doing that though as the unit has some weight to it. You may need to tap on the rounded extensions on the nut to break it loose or insert a scewdriver into the holes and turn it. If you have a dishwasher connected directly into the disposer, you need to disconnect the hose also.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 09:42 PM
Disposal & Sink w/back set drain??? Kathy Plumbing 2 03-04-2007 02:48 PM
dishwasher/sink disposal TonyD Electrical 1 10-22-2006 02:06 AM
DIY Garbage Disposal replacement bigbob Plumbing 1 06-07-2006 06:05 PM
Garbage Disposal on a "Grey-Water" line? Ron Plumbing 8 02-06-2006 08:25 PM
