Old 01-27-2009, 07:26 PM   #1
Don't know it all, yet!
Tailpiece question
I'll show my ignorance here but....
The other day I was at a local Tractor Supply store and saw some of their plumbing fittings in a sale bin. These fittings looked somewhat like a reducing bushing on one end and the other end had a flat lip at the very end. Some were pvc, some were copper. The fitting is open all the way through, does not close like a cap plug does. Somewhat like a "T-nut" if you are familiar with that hardware, i.e. round barrel with a flat lip on one end.
The bar code label identified this as a "tailpiece." The only tailpiece that I am aware of is on a sink trap, tub, etc. The store clerk said he did not know what it is used for.
I tried a Google on this but didn't find anything. Just curious.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 01-27-2009, 11:55 PM   #2
Tailpiece question
Did it look like this:
This is the only "tail piece" used in plumbing that I am aware of, and it's a perfect example of a brass or chrome plated brass tail piece. They also come in plastic as well.
The tail piece is part of the drain under a sink. On a kitchen sink it goes between the strainer basket and the P-trap. On a bathroom sink, the tail piece will actually be part of the Pop Out plug assembly that forms the drain, or it will thread into the drain with a fine thread.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
