Taco 219-4 Flo Check Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2012, 12:06 PM   #1
taco 219-4 flo check installation
is it possible to replace just the "guts" of this check valve without haveing to sweat a new one in? I replaced a tempering valve this way ...can the same be done for this?
Nubeee is offline   Reply With Quote
Old 01-15-2012, 12:43 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Taco
Taco 219-4 Flo Check (3/4" sweat, bronze body) is designed for use in hot water heating systems to prevent gravity circulation when the boiler is operating, but the space heating zone is not wanted.
Taco 219-4 Flo Check allows to use the heating boiler for domestic hot water throughout the whole year.
Looking at the picture... probably so.
Old 01-15-2012, 12:59 PM   #3
My concern is pressure? This valve is for baseboard heat ...and I dont know what kind of pressure will ensue once I take it off? I turned on a hot water faucet to aleviate pressure when i did the mixing valve and very little water came out...hoping this is similar? Any thoughts?
Old 01-15-2012, 01:05 PM   #4
MarginallyQualified
Any thoughts?
Yeah, you'll need to shut it all down beforehand.
Didn't realize I needed to say that.
Contractor 5% Off for Cash NOT Check? redavalanche General DIY Discussions 11 05-26-2010 10:28 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
