T-shaped Tub Drain Exist? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2007, 10:20 PM   #1
I'm installing a jetted tub in my basement and I'm forced to install the drain-side of this tub away from the drain location by some distance due to needing access to the jet water pump. I would like to know if a fitting exists that would allow me to run the opposite direction of the typical overflow/drain combination. Everything would run along the length of the tub and then down into the drain rather than draining just beneath the overflow drain.
To summarize, I would like to attach to the overflow then extend down, turn 90 towards the tub drain then continue on to a roughed-in drain in the concrete ~4ft away.
I realize that I could set the tub high enough to get the normal drain rerouted but this would look awkward.
blueboy27 is offline   Reply With Quote
Old 10-31-2007, 12:25 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You can do an offset with all glue joints, but I think max distance by code is 30" but don't quote me on that.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old Type Bath Drain Tool Junkie Plumbing 4 09-26-2007 03:05 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
