T&P Valve On Tankless Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2012, 11:56 PM   #1
Rewards Points: 2,210
T&P valve on Tankless Heater
I have a Tankless heater, for a while now the T&P valve has been discharging slightly when you turn off a hot water tap. I was told this is normal. Is it?
Now the T&P valve is leaking constant when you use hot water. The water temperature is not overly hot coming out of the relief vlave, I can hold my hand in a pail of it for a minute or so. Wanted to take a temperature on it but do not have a thermometer.
The tank was at 50C and I turned it down to 40C and it leaks a lot less water but still does leak a little.
We also had a power outage if that makes any difference, although we were on holidays, however 4 showers were taken and 3 loads of laundry done before it started to leak after we got back.
Figuring I'll probably just change the T&P relief valve and see if that does it.
Any other thoughts or ideas?
mae-ling is offline   Reply With Quote
Old 03-29-2012, 04:33 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
The TP valve should not normally leak. I would change it. If the new one leaks, the pressure in your system is to high and you could need an expansion tank.
Coastal South Carolina
Old 03-29-2012, 07:40 AM   #3
nothing has changed in the system so why the need for an expansion tank now?
This is not a closed system, just a normal household system.
Old 03-29-2012, 09:20 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You shouldn't need an expansion tank on a tankless water heater.
I'd check the pressure on the house before you go to the extent of changing the T&P valve.
I'm betting the pressure is a little high, and the act of water hammer is pushing the valve open a little.
Journeyman Plumber
Old 03-29-2012, 09:54 PM   #5
If the pressure is high to the house then why would lowering the tempo make it leak less?
Old 03-30-2012, 10:50 AM   #6
Chicago, IL
Michael Thomas's Avatar
BTW, manufactures typical specify a pressure, not a temperature and pressure, relief valves on thankless WHs.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
jaydevries (03-30-2012)
Old 03-31-2012, 10:14 PM   #7
Change it with one with the same rating, works good now
T&P Valve Keeps Pouring Hot Water cazntiger Plumbing 2 10-23-2011 07:12 AM
Re-installing saddle valve on newly installed water heater connections bkraz Plumbing 18 12-16-2010 02:51 PM
Water Heater valve question bfan781 Plumbing 5 08-15-2010 10:45 AM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 08:08 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
