T&P Valve (new) Leaks Also.... - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2009, 08:02 PM   #1
T&P valve (new) leaks also....
Hello,
I have a Reliance 501 47 gallon electric water heater. The T&P valve leaks when the top element cycles on. I have replaced the T&P valve, installed new thermoststs (upper and lower). I have turned down the water pressure to about 60psi. The (new) T&P valve leaks. The only way to get the T&P valve to stop leaking is to turn both thermostats to just above lukewarm. Thoughts? Very confusing!
Thanks,
rubani is offline   Reply With Quote
Old 11-08-2009, 08:05 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
While it's crazy even new parts right out of the box can be bad.
Replace the tpv with another new one..maybe a different brand.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-08-2009, 08:07 PM   #3
Will do. Dumb question..... Is there a short and long version of the T&P valve? The reason I ask is could the tip of the T&P valve be too close of touching the top element causing it to open?
Thanks.
Old 11-08-2009, 08:24 PM   #4
Rewards Points: 560
I don't think so
Did you compare the lengths of the one you replaced with the new one?
Old 11-08-2009, 08:29 PM   #5
Yes and bought the same. Did not know if previous homeowner had previously replaced it or not.
Forgot to mention....I think the problem started when water company required the installation of a double check valve at the meter. Could I have an expansion problem?? Have not checked the pressure as the water heater does a complete cycle.
Is an expansion tank necessary if there is a checkvalve installed in the system?
Old 11-08-2009, 09:21 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
They do make long and short shank T&P valves. Most water heaters require the short shank, but not all.
The fact that the t&p started leaking after the installation of a check valve indicates that there is an expansion issue. An expansion tank is necessary on a closed system which is what you now have. Previously, the water had a place to expand to...namely back out into the city main. Now that the system is closed due to the check valve, the water has no place for expansion. Install an expansion tank and I'm pretty confident your problem will be solved.
JDC is offline   Reply With Quote
Old 11-08-2009, 10:32 PM   #7
JDC is right on the money. I will just add that you make sure you pump up the expansion tank's pressure to the same 60psi your PRV is set to and replace the T&P after you finish installing the expansion tank.
plumber Jim is offline   Reply With Quote
Old 11-09-2009, 02:13 PM   #8
Appreciate all the help!! Will do as advised.
Tags
pressure valve , t&p valve
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
sprinkler valve leaks deck hand Landscaping & Lawn Care 3 06-20-2008 08:36 PM
anti freezing stop and waste valve leaks James Parsons Plumbing 1 10-07-2007 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
