T Bolts Too Long, Tell Me How Simple This Should Be - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2009, 05:17 PM   #1
Rewards Points: 264
T bolts too long, tell me how simple this should be
Its the simple things that stump us some times..... Put down new toilet, new bolts, the whole shabang. Go to put caps over the T-bolts and they won't grab bc there's too much excess bolt sticking up. They aren't the snap off type, and I'm thinking if I use a hacksaw the nuts probably won't come back off. I want to be done with this darn thing tonight, thoughts?
moneymgmt is offline   Reply With Quote
Old 03-24-2009, 06:04 PM   #2
I just use a hacksaw, carefully so you don't scratch the toilet, or you could take up the toilet and use shorter bolts.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 03-24-2009, 06:30 PM   #3
Safe, Most of the Time!!
brokenknee's Avatar
Use a hacksaw, they will come off when the time comes.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 03-24-2009, 08:39 PM   #4
Dave E's Avatar
Send a message via Skype™ to Dave E
Dremmel with a cutting disc works pretty good. More precise than a hack saw.
Dave E is offline   Reply With Quote
Old 03-24-2009, 11:45 PM   #5
Gerry I
Yeah, a hacksaw works ok but if you're in a big hurry like I usually am, then grab your hand-held grinder...SWEET!!...DONE!!
PS. A quick tip for you. If you place a stainless steel washer on the bolts first, before you put on the plastic washer, it will hold the plastic washer up off of the toilet just enough to make it real easy to snap on the cap. I've been doing that for years and it's real slick.
Happy Plumbing!
Gerry I is offline   Reply With Quote
Old 03-25-2009, 11:14 PM   #6
Rewards Points: 562
A bolt cutter works faster yet. The nut will clean up the threads as it comes off,,,not to worry!!
4just1don is offline   Reply With Quote
Old 03-26-2009, 06:46 AM   #7
if you used 2 nuts on the bolt, one to stabalize it to the flange and the one on top of the washer under the china cap you can just take your nut driver and bend the top of the nbolt back and forth until it snaps off, then retighten the nut again just to make sure...if you use a hacksaw make sure to clean all the shavings up, they will stain the porcelain.
zosoplumber is offline   Reply With Quote
How Long Do We Have? Docfletcher Off Topic 19 05-01-2010 11:02 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
simple closet lighting theboss Electrical 8 02-16-2009 08:56 PM
Painted bolts zcb Painting 2 08-21-2008 01:08 AM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
