T & P Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2012, 01:55 PM   #1
T & P Valve
Trying to remove T & P valve but the water heater starts to turn Any recommendations to prevent the water from moving
pcd913 is offline   Reply With Quote
Old 12-18-2012, 02:17 PM   #2
Rewards Points: 660
...probably going to need some clarification.
B
Beepster is offline   Reply With Quote
Old 12-18-2012, 05:05 PM   #3
Special User
Rewards Points: 1,230
Do you have a helper that can hold the heater still while you crank on the wrench?
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-18-2012, 05:53 PM   #4
DIY staff
Rewards Points: 7,174
Our computer glitch got you----please try to describe your situation again----Moderator
Old 12-18-2012, 05:59 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,048
Ayuh,.... Have yer fat nephew hug it Real Tight, while yer turnin' it....
Bondo is online now   Reply With Quote
Old 12-18-2012, 08:04 PM   #6
Thread killer
Rewards Points: 272
HAHAHAHAHA
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 07:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 12:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
