System For Increasing Home Water Pressure? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2011, 03:52 PM   #1
System for increasing home water pressure?
Are there inexpensive methods of increasing the water pressure for a small residence?
Thanks for your ideas.
Daulton is offline   Reply With Quote
Old 03-20-2011, 03:55 PM   #2
Water Treatment
Rewards Points: 848
Knowing what you have right now for in coming water, well, city....
What size of lines are running through the house?
Akpsdvan is offline   Reply With Quote
Old 03-20-2011, 04:45 PM   #3
how
Rewards Points: 1,100
Are you wanting higher pressure or water flow? Are you sure that your house water shut off or the water shut off on your property line is fully open? Do you have a pressure reducing valve near your house shut off valve that can be adjusted. What size is your lines into the house? What pressure do have right now?
how is offline   Reply With Quote
Old 03-20-2011, 05:24 PM   #4
Daulton,
I hate to break it to you but it looks like you'll need to replace all the galvanized lines in your daughters house. The occlusion in the 3/4" pipe you mention here, DIY Comedy--PVC for main water line?is probably the reason she is experiencing low water flow. They are notorious for this.
VIPlumber is offline   Reply With Quote
Old 03-20-2011, 08:47 PM   #5
how
Hey Daulton
Asking that question without referencing your other posting that gives more complete info wastes people's time here.
Old 03-20-2011, 11:35 PM   #6
no theres not
there is not an inexpensive way to increase your water pressure . the pressure is set by city and regardless of pipe size pressure remains the same, if you have 90 psi it doesnt matter if you have 1/2 inch pipe or 4 inch pipe the pressure will still be 90 the problem you are probably noticing is that turbulence is slowing the water down as it flows thru pipe that has mineral buildup inside like little mountains they interfere with the flow , pipe size has to do with the volume of water being brought to your house you want to have a good size coming in to your house depending on the number of fixtures you have 1 inch is good to bring from the main then reduce to 3/4 and run 1/2 inch to fixtures depending on type of fixture this should give you the flow your looking for , copper is best choice of pipe , good luck
vond93 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 08:45 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 10:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
