Old 11-16-2012, 05:29 PM   #1
dbt
dbt's Avatar
Symmons valve lug bolt
I have a new Symmons valve on my outside shower and can't remove the little threaded 'lug' nut underneath the valve for final winterizing.
Has anyone a suggestion for removing?
Thanks, Dennis
dbt is offline   Reply With Quote
Old 11-16-2012, 05:35 PM   #2
Got a picture or at least a web site of that type valve?
Symmons makes dozens of differant products.
Old 11-17-2012, 05:11 PM   #3
A 3/8" socket wrench fits in perfectly
SuperPlumberGuy is offline   Reply With Quote
Old 11-17-2012, 10:24 PM   #4
You don't need to remove that plug. Just remove the TA-10 stem/cartridge.
Edited to add: I'm a master plumber here in MA. I've been winterizing houses and outside showers for almost 20 years. You don't need to remove that plug.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
dbt (11-19-2012)
Old 11-19-2012, 06:47 AM   #5
dbt
dbt's Avatar
Thanks for the replies. My sense tells me Ishmael is correct. That there won't be enough residual water to cause a problem.
Dennis
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
leaks on rear base of toilet & water supply valve Nospammer Plumbing 1 08-16-2012 04:21 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
