Symmons Temptrol Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2012, 12:22 PM   #1
Symmons Temptrol shower valve
Lack of hot water staying hot is the problem. Pressure is fine. Rest of the house and other shower with the same valve is fine so not the furnace/hot water supply. Replaced the spindle assembly and no better. Set safety stop to max . Are there other moving parts that can't be seen/replaced or can these valves get clogged up with hard water deposits limiting the hot water supply?
CoachRonNelson is offline   Reply With Quote
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
Replacing Shower Valve suncowiam Plumbing 18 06-01-2011 12:49 AM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 05:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
