Symmons Rough-in Valve Flow Adjustment Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2013, 03:40 PM   #1
Rewards Points: 16
Symmons rough-in valve flow adjustment problem
Hi guys,
I have a lack of volume adjustment on the new Symmons rough-in valve I just installed.
It starts out ok but then it goes to full blast with no in-between.
Anybody know what the problem might be ?
A quick video showing the problem :
www.youtube.com/watch?v=vPRtPtX45FY
Thanks everybody in advance!
Gabe9195 is offline   Reply With Quote
Old 05-13-2013, 06:09 PM   #2
Rewards Points: 582
did you remove the cartiridge befored you soldered in the unit...ben sr
Old 05-13-2013, 06:21 PM   #3
Rewards Points: 16
I did not.
But I have removed it earlier today and it looks perfect.
I can only see a seal at the end with a screw in the middle of it and another one further out, they're both perfect.
Somebody on a diff forum said that this valve may just work this way and that the volume control is done via the lever below the main knob?
That's exactly the way that the similar Symmons valve works in the shower stall in the other bathroom
Couple of pictures of the set-up:
Access panel in the bathroom on the other side of the wall, allows me to access the shut-off valves:
Old 05-13-2013, 07:08 PM   #4
Rewards Points: 32
The volume is controlled with the diverter. Move it towards the middle to slow the flow. The main handle just controls temperature.
Dan
djlandkpl is offline   Reply With Quote
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Hot water flow problem kmccoy Plumbing 4 11-25-2012 06:49 AM
Galvanized piping and Rough in valve geomeo Plumbing 5 10-13-2012 10:11 PM
Can't Identify Shower and Tub rough in valve stamped SHWR 7196 and TUB P-P USA help4diy Plumbing 1 11-21-2010 09:06 AM
Flow not Pressure problem??? DonM Plumbing 5 11-29-2007 05:53 PM
