Switching Kitchen Disposal From Right Side Of Sink To Left? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2009, 01:26 PM   #1
Rewards Points: 682
switching kitchen disposal from right side of sink to left?
I am planning to replace all the plumbing beneath our kitchen sink. The drain pipe into the wall is too high and long, and at a bad angle, so I am thinking about installing the kitchen disposal on the left side instead of the usual right side of the sink. This way I can arrange the plumbing in a more intelligent fashion (the way it is now is terrible).
I don't think this change would be a big deal, but I am not an experienced plumber. Could there be any possible problem with this change?
darsunt is offline   Reply With Quote
Old 03-11-2009, 01:58 PM   #2
Rewards Points: 150
If the drain line coming out wall is to high for proper drainage for the p traps then you either have to get a shallower sink or lower the drain line.
rudolph58 is offline   Reply With Quote
Old 03-11-2009, 04:29 PM   #3
Rewards Points: 150
rudolph58
If the p trap drains are higher than what is coming out wall you will either have to get deeper seal traps,install a shallower bowl sink or lower the waste pipe coming out of the wall.
Old 03-11-2009, 07:42 PM   #4
Rewards Points: 682
shallower sink is an interesting option, but I have lots of dishes!
I don't want to change the drain pipe, because that stuff is all old galvanized pipe.
I may barely make it work if I switch the disposal to the left side.
Kitchen sink rough-in... skipjack Plumbing 1 09-29-2008 05:00 PM
drain rough-in for kitchen sink amakarevic Plumbing 1 07-27-2008 06:59 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
