Switching To A Fluidmaster Fill Valve Inside An Old Briggs Tank. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2012, 10:15 PM   #1
Switching to a fluidmaster fill valve inside an old briggs tank.
Will a Fluidmaster 400A toilet tank fill valve fit inside a briggs 4920 tank?
It says fits most tanks, if it doesn't which one would fit?
I need to replace the old fill valve with ballcock, thanks.
pinecone12 is offline   Reply With Quote
Old 01-19-2012, 10:20 PM   #2
Rewards Points: 12,886
I've never even heard of a Briggs tank.
It's a $10.00 part, if it does not fit bring it back.
Old 01-19-2012, 10:41 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
As long as you have around 14" of height inside of tank it should fit
plummen is offline   Reply With Quote
Old 01-19-2012, 11:02 PM   #4
Rewards Points: 582
yes it will fit ..remember its adjustable...
Old 01-19-2012, 11:53 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 984
How old? If itís the 50/60s briggs case,it will not work. 14920
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-20-2012, 08:59 AM   #6
Inside the tank it has 2 sets of numbers. 4920, 4930.
Date of manufacture 07/94. This is a discontinued model.
I bought one of those replacement kits at a hardware store
and I think the fill valve is not compatible with the tank.
It leaks from under the nut even after making sure it was on tight.
As you can see on pic#2 there is a gap.
Old 01-20-2012, 11:54 AM   #7
plummen's Avatar
Did you install the rubber washer inside?
Old 01-20-2012, 03:12 PM   #8
Yes, if you are referring to that black rubber gasket on the fill valve.
Old 01-20-2012, 03:30 PM   #9
plummen's Avatar
The rubber washer inside the tank does the actual sealing,the nut just puts pressure on it.
Can you move the fill valve side to side when you push/pull top of it?
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
fill valve, boiler related pmacedo HVAC 15 12-31-2007 12:45 PM
Toilet Flushing ? Piney Plumbing 5 10-20-2007 02:56 PM
