Switching From Expansion To Compression Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2011, 05:40 PM   #1
Rewards Points: 392
Switching from Expansion to Compression Pex
Hi,
So I've been doing DIY expansion PEX for several years now and I generally love it, I have the expander tool, and the pipe is reasonably priced.
This is basically Wirsbo, Pro-Pex, Uponor, etc..
However, I'm playing around with solar and pool heating and the cost of a simple 1/2 inch ball valve from pexsupply.com is like 12 bucks! I can't justify doing any projects because it costs so fricking much to do anything..
So basically, my plan is to keep my stock of fittings and do expander pex when I think it makes sense, but start working on using some compression fittings on my pex-a tubing, which seems like it supports both, if i stick with the pex-a seems like I can have the best of both worlds, use the expander tool for my general home plumbing projects, but for my hobby projects, use a more affordable method..
Has anyone else been in this boat? What kind of crimp tool did you buy, and can you recommend a good source to get the tool and the crimp fittings, etc..
zootjeff is offline   Reply With Quote
Old 11-18-2011, 06:18 PM   #2
Rewards Points: 392
So I guess no one has used both compression and expansion fittings and has any comments... Oh well.
Intermittant total compression loss? johnd393 Automotive Repairs 7 07-26-2014 11:08 AM
Expansion joint john4153 Plumbing 0 10-05-2011 07:51 PM
PEX: Expansion vs Compression Hauki Plumbing 8 09-28-2011 12:03 AM
Ceiling Anchoring of Compression Poles planar Building & Construction 1 08-07-2011 03:28 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 05:44 AM
