Sweaty Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2009, 10:48 AM   #1
Sweaty pipes
I just noticed that the copper water pipe that comes into the basement from the muni water supply has a lot on moisture on it. It is on the connections to, and the bottom of, the water meter as well. There are no leaks. The pipes are cold and I am sure it is just condensation. It does not drip, so it's not a lot. I have never noticed this before. I have finished the basement area that the meter is in and had planned to frame around these pipes and the meter, with an access panel for access. Can I wrap rags, or some kind of tape, around the pipe to keep it from possibly dripping, or to stop the condensation all together? Any suggestions appreciated. Thanks!
Woodcutter is offline   Reply With Quote
Old 03-30-2009, 11:00 AM   #2
RippySkippy's Avatar
The only ways to stop the condensation is to remove the moisture in the air where the pipe is located or insulate the cold incoming water line from the conditioned air. You have 52*+- water coming into a conditioned air space and that will draw moisture to the pipe. You would be best off finding some good pipe insulation and insulating the pipe. I wouldn't go the rag route....
If you decide to box this pipe in...put a small return air vent at the bottom and top of the space, this will at least allow for air to circulate through the space via natural convection and help keep it dry. But if you insulate the pipe well...this many not be necessary.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 03-30-2009, 12:47 PM   #3
Remodeling Contractor
Just wrap with the rubber pipe insulation.
Old 03-30-2009, 12:56 PM   #4
Thanks guys. If I wrap it in the black foam pipe insulation I have seen, does that stop the condensation, or does the moisture collect inside the insulation?
Old 03-30-2009, 01:01 PM   #5
that is the stuff to use. For cold pipes we use it to stop condensation for hot pipes it is used to stop loss of heat.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Frozen Pipes? Plugged pipes? brokenhammer Plumbing 7 01-15-2009 11:10 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
