Sweating Toilet Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2011, 02:19 AM   #1
I have a sweating toilet tank in the basement and upstairs, but the one downstairs is really bad. There's water all over the floor due to it.
I've setup a dehumidifier in the basement to help with condensation, and added a higher CFM bathroom fan to get rid of water vapour faster following showers. Is there anything else I can do?
design_lover13 is offline   Reply With Quote
Old 07-15-2011, 02:20 AM   #2
Note, I've also checked for a leak into the toilet bowl using dye, but that doesn't seem to be the problem. It would make sense though, assuming that the cold water is constantly filling the tank making it sweat.
Old 07-15-2011, 07:03 AM   #3
There are styrofoam insulation kits available for the inside of toilet tanks. They help the problem of sweating. But as suggested, check for leaks, inside and out. If the flapper valve is leaking water from the tank to the bowl, the tank will be constantly refilling with cold water.
Old 07-15-2011, 07:49 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
When the water in the tank reaches room temeperature it should not be sweating. If after several hours of no use it is still sweating you need to check that the flush valve isn't seeping and that the commode is shutting off properly. A seeping flush valve will allow a commode to continually fill with fresh cold water. If it is shutting off and stops sweating after the water warms up, then it is only a problem for a period of time until the tank water warms. Some people run a mixing valve to the toilet supply that allows a small amount of hot water to temper the tank water so it stays above dew point.
Old 07-15-2011, 08:16 AM   #5
Rewards Points: 16
Are you sure the bathroom fan is venting outside?Is the fan on a timer to keep running for 30 minutes or so after the shower is done? With the humidity in toon town recently is this a recent problem or does it happen in winter also?
daveb1 is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Leaky Toilet Tank Valve Tuckahoe Sparkplug Plumbing 4 07-10-2010 07:21 AM
Sweating toilet tank Tekno9000 Plumbing 6 01-30-2010 02:22 PM
Bubbles In Toilet Tank JCNimmo Plumbing 2 01-29-2010 09:11 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
