Old 04-05-2009, 10:04 AM   #1
Sweating the threaded end into a shower valve
I'm installing a bathroom in my basement, I'm done with the PVC Drainage plumbing under the concrete and bathroom framing. I'm about to start installing the copper water lines (shower/vanity/toilet). Question; I'm going to sweat/solder the threaded end into the shower valve.. has anyone else ever done this? or recommend this? I've been told it's common and has a less chance of leaking then tape and pipe dope.
dab3ar$ is offline   Reply With Quote
Old 04-05-2009, 11:07 AM   #2
HVAC / Plumbing
never done it.. Always used pipe dope.. Not a fan of tape
kenmac is offline   Reply With Quote
Old 04-05-2009, 11:21 AM   #3
I've seem it done, But I wouldn't do it. It sure would be fun to take it apart some day.
plumber Jim is offline   Reply With Quote
Old 04-05-2009, 11:24 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
I've done it before....on a European faucet a friend ordered on ebay. The threads while 1/2", werent tapered so the adapters just bottomed out without becoming tight. Its not something I would recommend unless in unusual circumstances. That being said however....some tub/shower valves are designed to accept 1/2" copper tubing (sweat) OR 1/2" female adapters. If you do decide to sweat anything into the valve body itself, be sure to remove any parts which might be damaged from the heat.
JDC is offline   Reply With Quote
Old 04-06-2009, 09:22 AM   #5
I never had a teflon taped/compounded thread leak if tightened properly. But if you want to solder it, you need to remove all the guts of the shower body. Including all the ,"O" rings that are in there at the bottom.
Ron
Old 04-11-2009, 09:41 AM   #6
I appreciate everyone’s reply, it helps me tremendously, being this is my first time installing a shower/tub valve.... all I can think of is a leaky messy mistake. Now I can install it properly and move on… thanks once again!
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
Do the fittings need to be sweated before being installed on shower valve? twilightcall Plumbing 5 08-25-2008 12:47 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
