Sweating Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2010, 06:28 PM   #1
sweating copper
Are there any secrets or products to put inside existing water lines to stop the drip while sweating joints together.
rlaurent79 is offline   Reply With Quote
Old 08-11-2010, 06:55 PM   #2
Rewards Points: 150
i've seen little glycerine balls, looks like a giant "horse pill" at home depot for that job...
i've used a wad of bread before, shove it up there and it will disolve
johnnyboy is offline   Reply With Quote
Old 08-11-2010, 07:34 PM   #3
DIY staff
Rewards Points: 7,174
JohnnyBoy has it--Wad of white bread---or the little jelly balls.
Old 08-11-2010, 11:02 PM   #4
Owner
LateralConcepts's Avatar
Yeah "white" bread. Not pumpernickel, wheat, any of that other healthy garbage. I always take the crust off, break off what you think you need, then roll it in a ball tell it's kinda doughy, jam it in and sweat.
If you wanna get fancy you can use a tool called a Jet-Swet http://www.brenelle.com/
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-11-2010, 11:06 PM   #5
ok, thanks guys
Old 08-11-2010, 11:07 PM   #6
Electrician
Proby's Avatar
Does the bread trick work for electric too??
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-11-2010, 11:16 PM   #7
Owner
Maybe if you want toast
Lateral
(208) 818-8241
The Following User Says Thank You to LateralConcepts For This Useful Post:
Proby (08-12-2010)
Old 08-12-2010, 03:51 PM   #8
Handyman
Rewards Points: 512
Don't forget to unscrew any aerators you have on faucets, etc to let the bread residue flow out or you find low pressure
canadaclub is offline   Reply With Quote
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 10:06 PM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 10:23 AM
copper flashing, galvanized nails... sharp Roofing/Siding 4 04-02-2010 07:43 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
The "ART" of sweating copper Joe F Plumbing 5 07-01-2008 12:55 AM
