Old 07-20-2009, 02:42 PM   #1
Sweating a brass fitting to a copper pipe
When sweating a brass fitting to a copper pipe, how do you when to
remove the torch and apply the solder?
jgs1951 is offline   Reply With Quote
Old 07-20-2009, 02:47 PM   #2
Moderator
Termite's Avatar
Brass takes more heat. A common mistake is to overheat to the point that your flux melts away. Use good thick flux or you'll fight it...The black stuff that comes in the little snuff cans will cause you headaches a lot of the time.
I heat my fittings and touch the solder to the OPPOSITE side of the fitting as the flame...When the solder melts and sucks in you know you've got it and can pull the heat off. Remember that the solder is drawn toward the flame so you shouldn't apply the solder where the flame is held.
Old 07-21-2009, 11:02 AM   #3
Thanks thekctermite, Very helpful reply.
Old 07-21-2009, 06:00 PM   #4
I just did this in my office, I had to remove a coupler and insert a T to provide water in the warehouse for the swap cooler, just make sure you heat the pipe enough so the solder stick instead of run off.
cochise7969 is offline   Reply With Quote
Old 07-21-2009, 07:39 PM   #5
Thanks for the help cochise7969
Old 07-21-2009, 08:40 PM   #6
Man of many hats
wrangler's Avatar
And just a clarification, when soldering brass to copper, apply the heat to the brass first. The copper heats faster than brass.
Man of many hats
wrangler is offline   Reply With Quote
Old 07-21-2009, 08:56 PM   #7
Thanks wrangler for a valuable tip
Old 09-26-2011, 07:31 PM   #8
Exactly what flux and what solder are we talking about.?I have the problem with a toilet drain.
Gerry Hendry is offline   Reply With Quote
Old 09-26-2011, 10:06 PM   #9
Doing it myself
Alan's Avatar
You are probably not getting it hot enough. You might need oxy-acetylene to get it hot enough. A regular can of propane and a cheesy torch head aint going to do it.
Journeyman Plumber
Need Tips To Unscrew 30-year Frozen Brass Pipe Fixture artdunbar Plumbing 4 03-12-2009 12:38 AM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 07:38 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 10:50 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 11:55 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
