Old 10-18-2007, 11:28 AM   #1
47_47's Avatar
Sweating Ball Valves
Are there any tricks to sweating in a ball valve? Should you open, close or part way open the valve? I have sweated in gate valves and always removed the stem.
Thank you
47_47 is offline   Reply With Quote
Old 10-18-2007, 11:35 AM   #2
Custom Cabinet Maker
open valve, REMOVE HANDLE
skymaster is offline   Reply With Quote
Old 10-18-2007, 02:40 PM   #3
RippySkippy's Avatar
In addition, I try to cool the valve ASAP with wet rag when I'm done.
RippySkippy is offline   Reply With Quote
Old 10-18-2007, 08:37 PM   #4
Send a message via AIM to Marlin
Usually I sweet with the valve open. Their have been a couple situations where for one reason or another I did it with it closed. I never had a problem either way. What you do not want to do is work the valve while it is hot.
I don't know why you would remove the handle?
Marlin is offline   Reply With Quote
Old 10-19-2007, 12:34 AM   #5
I open the valve and wrap a wet rag all over it.
scorrpio is offline   Reply With Quote
Old 10-19-2007, 10:53 AM   #6
47_47's Avatar
Thanks for the advice. I'll open the valve, remove the handle and wrap the valve with a wet rag. I'll also not move the valve until it has cooled.
Old 10-20-2007, 02:45 PM   #7
Doing it myself
Alan's Avatar
We sweat ball valves with the valve fully open to prevent pressure buildup on the supply side and a blow-off before the solder has fully set.
As far as taking the handle off? No, just be careful not to torch the darn thing or the rubber will melt off.
Not working it while it's hot? I can see that, but we do. I don't think the ball gets quite hot enough to expand and damage it, but I guess safe is better than sorry. Good luck
Journeyman Plumber
Old 10-21-2007, 09:13 PM   #8
I just open the valve. I've never seen the need to take the handle off. Never had any leaks from the ball either.
Go Buckeyes
Buckeyetech is offline   Reply With Quote
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 10:12 AM
Ball vs. Gate Valve BigJimmy Plumbing 10 06-02-2007 07:49 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
Soldering 1/4 turn valves Manuel6 Plumbing 2 12-11-2006 03:32 PM
