Sweating - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-25-2011, 08:31 AM   #1
Sweating
Am I asking for trouble if I sweat copper that will be under a slab? I have busted my floors up and I have to relocate some of the water lines to accommodate new design. The current pipes are over sixty years old and look pretty good. I think I once read that pipes under a slab have to be brazed. It looks like the original were sweat but I don't know how to tell.
Lew04 is offline   Reply With Quote
Old 05-25-2011, 08:48 AM   #2
we always had to silver solder any copper joints under a slab. i have repaired leaks under slabs with just regular solder tho. i really didnt have a choice. if you do id wrap some pipe insulation around the joints before covering them up.
Old 05-25-2011, 10:41 AM   #3
Rewards Points: 1,668
Danny, what is the purpose of the insulation around the joint?
bob22 is offline   Reply With Quote
Old 05-26-2011, 06:38 AM   #4
if you silver solder then it doesnt matter. i ususllay covered them to keep the soil off the joints if i had to use regular solder
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 09:06 PM
sweating walls ewf Building & Construction 4 03-31-2011 10:23 AM
lines sweating 7echo HVAC 3 09-07-2010 02:22 AM
Sweating toilet tank Tekno9000 Plumbing 6 01-30-2010 01:22 PM
Sweating interior walls mhpruitt727 General DIY Discussions 16 12-28-2009 09:22 AM
