Swapping The Toilet And Shower - Possible? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2011, 07:27 PM   #1
swapping the toilet and shower - Possible?
Before remodeling our bathroom, need to knowif we can swap the toilet and shower locations. Will the drain swap be OK?
Caryn is offline   Reply With Quote
Old 10-25-2011, 07:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope! Not at all.
Old 10-25-2011, 09:09 PM   #3
not swap you can change out the line to make it fit not to hard to do it
trankc is offline   Reply With Quote
Old 10-25-2011, 09:32 PM   #4
DIY staff
Rewards Points: 7,174
Much more info needed----a local plumber will likely need to look at the place and give you an idea if it's possible.
Is this a first floor--is the piping open from the basement? Have any pictures??
Old 10-26-2011, 06:57 AM   #5
You cannot simply "swap the drains". A toilet requires a 3" drain, and the shower is only a 2" drain. The plumbing configuration would have to be altered to rearrange the fixtures, which may or may not be very difficult - it depends. The degree of difficulty will determine the cost, and whether or not it's worth it to you.
If the bathroom is in the basement, or a 1st floor slab-on-grade home then there would be a big expense for breaking up the concrete and excavating (then backfilling and pouring new concrete). Conversely, if it's on a first floor with a full, un-finished basement underneath where every thing is readily accessible - no big deal. A 2nd floor bathroom would require you to either cut up the subfloor, or open-up the 1st floor ceiling to rearrange the plumbing.
Ishmael is offline   Reply With Quote
Old 10-26-2011, 06:40 PM   #6
Rewards Points: 582
yes more info needed...as ishmael stated commode 3" drain shower 2" drain what about venting changes etc.....more..more...more info......
Old 10-26-2011, 08:55 PM   #7
talking swap out the bath room that you have to take out dry wall so you can swap out for some one do the first time will need alot tool
the toilet can be 4 or 3 in if you have craw space then you will be ok to do it
lab house won't make it to much if you do by yourself
Old 10-27-2011, 07:09 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
These walls are weeping morons lately.
Getting worse by the day.
The Following 3 Users Say Thank You to Bud Cline For This Useful Post:
Alan (10-27-2011), AlbacoreShuffle (10-27-2011), Msradell (10-27-2011)
Old 10-27-2011, 07:20 AM   #9
Military Mom of 4
Snav's Avatar
Well they've covered the pipe issue.
To do it (in many areas - not all) you need a permit when any schematic layout of plumbing or electrical is changed and it must be inspected.
The necessary steps to secure the existing area to make sure the toilet area can support a filled tub - and that the tub area can support the toilet is important - usually a problem in bathrooms that have sustained water damage.
Now - doesn't mean it'll be easy. What's your underlying surface? Is this bathroom over a crawlspace: this would make access to the plumbing a little easier from underneath. Is it's a 2nd floor room: you'll have to create access either from the bathroom or from the room below - might not be simple depending on how tightly packed your plumbing is (etc). Is it on a slab: this would be quite complicated as rerouting any existing plumbing through slab means you have to love a jackhammer and love it a lot.
But - it's not impossible. . . I'm glad I rearranged the layout of my bathroom when I remodeled it - I swapped locations of all items (door, sink, tub, toilet) and love it NOW because it makes sense layout wise.
(edit - haha - this post is what happens when you let your reply sit on your computer for a long while before clicking 'send' - redundancy de la max)
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 10-27-2011, 11:32 AM   #10
AlbacoreShuffle's Avatar
Please push one for English .
AlbacoreShuffle is offline   Reply With Quote
Old 10-27-2011, 11:50 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A (friggen) MEN !
No chit!
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 10-27-2011, 12:24 PM   #12
Rewards Points: 2,238
Jeesh!
If the OP has a "craw space" and "alot tool" -
they'll be fine!
I learn so much on this site!
RF
rossfingal is offline   Reply With Quote
Shower noisy when toilet flushed joedadog Plumbing 3 04-27-2011 10:56 AM
Shower / Toilet Vent bigmatt Plumbing 2 12-05-2010 06:25 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 09:05 AM
