Swap One Shower Handle For Another - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2012, 07:35 AM   #1
Rewards Points: 350
Swap one shower handle for another
I have a shower, and it has one knob. This knob controls the temp as well as flow. I have it because it is so touchy, one little move to the left and it's scalding, one tiny tip to the right and it's demonically cold! Trying to adjust the pressure by moving the knob up and down also messes the temp, unless you are a magician and you can bring it up or down perfectly straight!
I want a setup that has temp control and flow separate. Is that possible to do? When my shower was leaking, I had to change the gaskets, and it involved pulling the cover off the shower wall, and extracting something the guy at Lowe's called "fat man", because it looks vaguely like a heft little man standing up. This was the guts of the shower.
I hope this enough information, what I am hoping is that showers are mostly plumbed up the same way, and once you get to a certain point, you can install whateve you want for faucet control.
Thanks for reading!
dougp23 is offline   Reply With Quote
Old 01-22-2012, 07:50 AM   #2
Rewards Points: 14,312
If you want all those features you would have to replace the whole valve. And no there not all the same.
Some have soldered conections, some have threads, some have unions.
About how old is the one you have now? Newer ones will have a build in anti scald valve.
I'd be inclined to take your valve stem apart agin and see if somethings missing, broken, loose. It should not be as senitive as yours seems to be.
oh'mike (01-22-2012)
Old 01-22-2012, 11:24 AM   #3
Rewards Points: 1,770
Turn down the thermostat on the water heater for a start.
bob22 is offline   Reply With Quote
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Broken Shower Faucet Handle DFT Plumbing 1 02-23-2011 08:55 AM
Stuck Shower Faucet Handle (Delta) Jeoroc24 Plumbing 3 03-03-2010 10:11 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Trouble replacing 2 handle shower levers matt7125 Kitchen & Bath Remodeling 2 12-02-2009 07:55 AM
