Old 11-13-2009, 09:21 PM   #1
suspended slab problems
I have just took on the maintance of a building which part of the floor is suspended concrete. The problem I am having is with the concrete breaking away from the cast iron waste lines. When a toilet flange breaks and the concrete has broken away I am having problems securing the toilet. I have been using hydraulic cement to set the bolts in, but if to much cement has broken away, what I put in falls through. Anyone have any suggestions other than going underneath and bouiling a form around the waste pipes? It is a pain to get to from the bottom.
keifer31021 is offline   Reply With Quote
Old 11-14-2009, 08:56 AM   #2
Remodeling Contractor
fill the void above with spray foam then use the concrete.
Drain Leak Causing Slab Problems? Texas Toast Plumbing 1 09-22-2009 10:37 AM
Help! Tile-over-concrete slab problems jeffchri Tiling, ceramics, marble 6 12-24-2008 06:22 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
