Suspect Cause Of Slow Toilet Flushing - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2013, 02:48 PM   #1
Rewards Points: 1,062
Suspect cause of slow toilet flushing
Geez- talk about more projects (currently have 3-4 threads going...LOL)
Should I start with roto rooting the vertical "air" pipe on top of roof of house? If so, what /why does that do the trick sometimes? What size snake/roto diameter ?
Thanks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-29-2013, 02:52 PM   #2
Rewards Points: 13,724
I'd start looking under the house at the clean out or remove the toilet and go through there.
If it was a vent all the fixtures would be slow on that line and there would be bubbling or guggles in the sinks or toilet.
noquacks (01-29-2013)
Old 01-29-2013, 03:27 PM   #3
did it just start flushing slow or has it always flushed slow? what brand of toilet? do you have hard water?
did it start flushing slow after you had company?
The Following User Says Thank You to DannyT For This Useful Post:
Old 01-29-2013, 05:46 PM   #4
good points, guys. its been that way for a while (1 montrh)
American standard (does it really matter?) yes, I have hard water. Also, how does that matter?
Old 01-29-2013, 06:07 PM   #5
Roofmaster
Rewards Points: 2,210
The reason that people go through the vent is that there are no traps in the way to interfere with the snake. Take off the toilet first like Joe says, and rapidly pour a 5 gallon bucket down the pipe, see what happens. also auger the trap in the toilet, especially if kids live there. They love to watch doo-dads sink.
The Following User Says Thank You to jagans For This Useful Post:
Old 01-29-2013, 06:28 PM   #6
ok, jag. But why is it not the same as dumping a 5 gal pail of water in the toilet itself- why does one have to remove the stinkin thing, to dump the water (presuming the toilet "curve" is free)? (Oh- no kids, daughter is pretty careful about drains and stuff. )
Old 01-29-2013, 07:11 PM   #7
Roofmaster
Yeah go ahead, try that first. Presuming. Good Point, but how does that isolate the toilet from the pipe?
noquacks (01-30-2013)
Old 01-29-2013, 08:22 PM   #8
Rewards Points: 952
Did he say that he has no kids, just a daughter who is careful?
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
paintdrying (02-02-2013)
Old 01-29-2013, 08:29 PM   #9
Rewards Points: 582
if you dump a 5 gal bucket straight into the bowl and if it flushes ok ..you have bad toilet... ..trap could be loaded with scale...ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Javiles (01-29-2013), noquacks (01-30-2013)
Old 01-30-2013, 07:37 PM   #10
Daughter is old, and married!! Not a kid anymore!! LOL
Old 01-30-2013, 07:39 PM   #11
OK, I get it now- thanks people. I will try this .
Also, update- found out the sink NEXT to the toilet is slow TOO! So, could be drain, or could be air "vent" tube, right?
Old 02-02-2013, 03:29 PM   #12
woahhhh! Pulled out a bunch of tree roots!! First time using a motorized 75 foot snake! Cool device. Just wanted to update you guys! Gonna add copper sulfate to drain from now on........
Old 02-03-2013, 06:46 AM   #13
location se? if you from around the se united states the tree roots are probably from bushes where the cast iron or whatever ran about a foot or two outside the slab for rough in. after rough in a cheaper thin pipe was probably used to finish to street or septic tank. if the house has a little age on it an old black fiber core pipe was probably used to do this. at the point the rough in pipe and the fiber core meet is probably your problem. builders planted shrubs up side of the house and roots from this grew in the line where they were just tapped together. locate this and then look downhill from there.
buddy builder is offline   Reply With Quote
Thumping sound when flushing the toilet Ginfay Plumbing 0 10-14-2012 08:48 AM
Flushing toilet causes black stuff in tub Matilda116 Plumbing 1 07-03-2012 12:06 AM
Slow filing toilet, fill valve already replaced SupraTT Plumbing 4 12-24-2010 06:52 PM
Replacing Slow Basement toilet NCJ Plumbing 3 12-09-2010 09:10 PM
Toilet UNDER Flushing...?? andsoitgoes Plumbing 20 07-26-2009 12:23 PM
