-   -   Suspect cause of slow toilet flushing (http://www.diychatroom.com/f7/suspect-cause-slow-toilet-flushing-170495/)
noquacks 01-29-2013 02:48 PM
Geez- talk about more projects (currently have 3-4 threads going...LOL)
Should I start with roto rooting the vertical "air" pipe on top of roof of house? If so, what /why does that do the trick sometimes? What size snake/roto diameter ?
Thanks!
joecaption 01-29-2013 02:52 PM
I'd start looking under the house at the clean out or remove the toilet and go through there.
If it was a vent all the fixtures would be slow on that line and there would be bubbling or guggles in the sinks or toilet.
DannyT 01-29-2013 03:27 PM
did it just start flushing slow or has it always flushed slow? what brand of toilet? do you have hard water?
did it start flushing slow after you had company?
noquacks 01-29-2013 05:46 PM
good points, guys. its been that way for a while (1 montrh)
American standard (does it really matter?) yes, I have hard water. Also, how does that matter?
jagans 01-29-2013 06:07 PM
The reason that people go through the vent is that there are no traps in the way to interfere with the snake. Take off the toilet first like Joe says, and rapidly pour a 5 gallon bucket down the pipe, see what happens. also auger the trap in the toilet, especially if kids live there. They love to watch doo-dads sink.
noquacks 01-29-2013 06:28 PM
ok, jag. But why is it not the same as dumping a 5 gal pail of water in the toilet itself- why does one have to remove the stinkin thing, to dump the water (presuming the toilet "curve" is free)? (Oh- no kids, daughter is pretty careful about drains and stuff. )
jagans 01-29-2013 07:11 PM
Yeah go ahead, try that first. Presuming. Good Point, but how does that isolate the toilet from the pipe?
cleveman 01-29-2013 08:22 PM
Did he say that he has no kids, just a daughter who is careful?
ben's plumbing 01-29-2013 08:29 PM
if you dump a 5 gal bucket straight into the bowl and if it flushes ok ..you have bad toilet... ..trap could be loaded with scale...ben sr
noquacks 01-30-2013 07:37 PM
Daughter is old, and married!! Not a kid anymore!! LOL
noquacks 01-30-2013 07:39 PM
OK, I get it now- thanks people. I will try this .
Also, update- found out the sink NEXT to the toilet is slow TOO! So, could be drain, or could be air "vent" tube, right?
noquacks 02-02-2013 03:29 PM
woahhhh! Pulled out a bunch of tree roots!! First time using a motorized 75 foot snake! Cool device. Just wanted to update you guys! Gonna add copper sulfate to drain from now on........
buddy builder 02-03-2013 06:46 AM
location se? if you from around the se united states the tree roots are probably from bushes where the cast iron or whatever ran about a foot or two outside the slab for rough in. after rough in a cheaper thin pipe was probably used to finish to street or septic tank. if the house has a little age on it an old black fiber core pipe was probably used to do this. at the point the rough in pipe and the fiber core meet is probably your problem. builders planted shrubs up side of the house and roots from this grew in the line where they were just tapped together. locate this and then look downhill from there.
