Supporting Vertical PVC Runs - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2010, 05:05 PM   #1
Supporting vertical PVC runs
Does no one worry about supporting PVC pipe on vertical runs? I have found virtually no mention of it between the book I bought, Google, and this forum. I remember reading somewhere that vertical pipe runs should be supported on each story (floor). Didn't find any products of use at both big box stores. I could use a riser clamp. The type that are used with steel/iron pipe but that seems like overkill. How is this handled in new construction?
FWIW the line I am constructing is a 1.5" dia drain/vent. It will run from the basement rafters up through one story, where a sanitary tee is, to the attic where it goes 45 degrees for a little bit and then finally out the roof.
paulyg is offline   Reply With Quote
Old 10-11-2010, 05:21 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 546
I generally set a coupling on top of the hole in the bottom plate. Since the hole is larger than the pipe, but smaller than the coupling, it won't fall through and will easily support 10' of DWV pipe. Same theory as a riser clamp. When doing a crawl space for instance, glue a short peice of pipe into a coupling, drop it in the pipe hole. Now go in the crawl, find the veticle pipe and finish the run. Hopes this helps
Old 10-11-2010, 06:54 PM   #3
Licensed Master Plumber
Two words. Riser Clamp they are required for every stack interval.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
OK to do a short, unsupported, vertical run of romex in finished wall? TomServo Electrical 2 10-04-2009 07:43 AM
runs and sanding oscarMadison Painting 1 02-24-2009 05:46 AM
moving wiring runs in attic DoubleD07 Electrical 1 07-23-2007 06:44 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 10:49 AM
