Supporting A Tub/shower Enclosure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2012, 10:03 AM   #1
supporting a tub/shower enclosure
I am installing a 1 piece MAAX tub/shower enclosure and have read information that supporting the bottom in a bed of mortar is recommended. MAAX does install a piece of chip board to the bottom of the fibreglass to lend support but I want to do this right. I was thinking that using expanding foam might do the job, has anyone used this or think that it would work?
screwy is offline   Reply With Quote
Old 01-02-2012, 10:06 AM   #2
Rewards Points: 13,694
Read the directions, no instrutions, go on there web site and get some.
Never use foam. as it expands it will lift or distort it and will compress when steped on.
The only time I've seen OSB used was for a protection for the bottom in shiping.
screwy (01-02-2012)
Old 01-02-2012, 10:39 AM   #3
DIY staff
Rewards Points: 7,174
Avoid the foam for the reasons listed above---use grout or masons mortar--
Joe---OSB bottoms have become fairly common with fiber glass tubs-Mike-
Old 01-02-2012, 10:57 AM   #4
thanks, yes I have read the instructions and have gone to the website. I understand what the recommendations and the common method of installation is, just thinking outside the box. There are many way to do things and I since they have low expansion foam for use around windows, this wouldn't necessarily distort the tub. I don't think that the distribution of weight over approximately 12 sqft. would be able to crush the foam, even if the Mrs. porks up.
Have you seen this tries and failed?
Old 01-02-2012, 12:17 PM   #5
Registered User
Rewards Points: 5,514
Screwy, please only post the exact same question in one thread, one forum, thank you.
Gary
PS. Add layer of plastic between OSB/wood and any water-added material. The OSB could suck the water out and mold.
Old 01-02-2012, 12:27 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So why then would you want to try to re-invent the wheel? Why not do as the manufacturer recommends?
this [foam] wouldn't necessarily distort the tub. I don't think that the distribution of weight over approximately 12 sqft. would be able to crush the foam, even if the Mrs. porks up.
Then do it if you think your knowledge is greater than that of the manufacturers.
Absolutely YES, I can't recall how many times.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
12penny (01-02-2012)
Structured wiring outdoor enclosure picflight Building & Construction 1 09-14-2011 03:43 PM
Cat enclosure Wiesbaden Building & Construction 0 09-04-2011 07:00 PM
Supporting a cathedral ceiling jmpn Carpentry 4 06-01-2009 10:29 AM
DIY replacement of neo angle shower enclosure feasible? hfoster Remodeling 4 02-14-2008 09:38 PM
Need help picking an outdoor enclosure coyote556 Electrical 13 08-06-2007 04:24 PM
