Supplying Fridge With Under-sink RO - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2011, 04:23 AM   #1
Supplying fridge with under-sink RO
Hi Guys,
I'm currently overhauling my kitchen and I was wondering what's the best way to supply my refrigerator ice/water system with water from the under-sink RO system I plan to get? I want to plan it out now while I'm partially down to studs. I was thinking I would just run that polyurethane tubbing from under the sink over to where the fridge will be (about a 15' run behind the cabinets). Will that do the trick? If so what size tubing do I go with, or is it all the same size? Is there a way to protect/insulate it since it will be running through my range? Part of the problem is that I don't have the RO system yet. Could I make a copper run in my walls or is that overkill? I'm not even sure that would work since I imagine everything is low pressure.
Thanks in advance!
Improvised is offline   Reply With Quote
Old 05-19-2011, 04:54 AM   #2
DIY staff
Rewards Points: 7,174
Most fridge lines are 1/4 inch---If you run it in the walls consider 1/4 copper and add nailing plates so you don't hit it with a screw while installing the cabinets.
Another method is to notch the bottom of the cabinets and run the line under the boxes.
I can't help with the insulation---never done that one.
Old 05-19-2011, 05:57 AM   #3
Rewards Points: 1,216
I would definitely install 1/4" copper rather than any flex tubing and do what oh'mike said.
COLDIRON is offline   Reply With Quote
Old 05-19-2011, 06:11 AM   #4
DIY staff
Nice plastic boxes with shut off valves are available---allowing you to recess the shut off behind the fridge---then add a separate line from the box to the fridge.----looks nice and is handy.
Old 05-19-2011, 07:13 AM   #5
Learning by Doing
Leah Frances's Avatar
Use the search function on this site. I did this project.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-24-2011, 08:29 PM   #6
I would have never guessed this myself, but I guess RO systems are corrosive to copper piping. I guess I'll have to keep it plastic or stainless steel.
Source: http://www.allgoodwaterfilters.com/1...e-osmosis.html
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
