Old 09-05-2010, 03:28 PM   #1
Supply valve to bath faucet doesn't stop water
I just moved into a house (built in 60s) and was about to replace a bathroom faucet. When I tried to turn off the faucet's hot and cold water supply valves, no matter how much I turned them, the cold water still ran fully and the valve started dripping slightly. The hot water slowed to a crawl but never fully stopped.
I suspect I should replace the supply valves with new ones? If so, I have a question about the shutting off the main water supply: We have a gas tank water heater. Next to it is the main water supply valve, a cold water supply valve, and the gas supply valve. Can I just turn off the main water supply valve or do I need to turn off the gas supply valve as well?
Thanks.
Kurt123 is offline   Reply With Quote
Old 09-05-2010, 10:24 PM   #2
PZ Reject...
just turn off the main and if possible open the lowest fixture....
Rambo is offline   Reply With Quote
Old 09-05-2010, 10:48 PM   #3
and when the system is drained, screw on a couple new stops so that you can shut it off when that glacier bay faucet leaks
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
Rambo (09-05-2010)
Tags
gas water heater, supply valve
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
