-   -   Supply valve to bath faucet doesn't stop water (http://www.diychatroom.com/f7/supply-valve-bath-faucet-doesnt-stop-water-80591/)
Kurt123 09-05-2010 02:28 PM
I just moved into a house (built in 60s) and was about to replace a bathroom faucet. When I tried to turn off the faucet's hot and cold water supply valves, no matter how much I turned them, the cold water still ran fully and the valve started dripping slightly. The hot water slowed to a crawl but never fully stopped.
I suspect I should replace the supply valves with new ones? If so, I have a question about the shutting off the main water supply: We have a gas tank water heater. Next to it is the main water supply valve, a cold water supply valve, and the gas supply valve. Can I just turn off the main water supply valve or do I need to turn off the gas supply valve as well?
Thanks.
Rambo 09-05-2010 09:24 PM
just turn off the main and if possible open the lowest fixture....
the_man 09-05-2010 09:48 PM
and when the system is drained, screw on a couple new stops so that you can shut it off when that glacier bay faucet leaks
