Supply Pipe Sizing For Bathroom/kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2008, 02:14 PM   #1
Supply Pipe sizing for bathroom/kitchen
I'm remodeling the 3rd floor of my house and it has a full bathroom and will have some kind of small simple kitchen (probably just a sink, maybe a dishwasher). The old pipes were 3/4" galvanized but they weren't hidden inside of walls so I will run new ones - they also supplied water to another kitchenet on the 2nd floor.
I'm trying to decide what pipe size to use but am having trouble finding information. The pipe coming into my house is 1" and stays 1" along most of its 30ft run along the basement. I have good pressure (at least 40psi). I think I'll just put in a 3/4" cold line like it was before, but am worried that a 3/4" hot line will make the hot water take a long time. So I'm thinking of doing a 1/2" hot line to the bathroom, and a seperate 1/2" hot line to the kitchen. Does this make sense? Could I just use a single 1/2" hot line? The fixtures would be about 25ft from the water heater in the basement, including a 14ft vertical. I'll be using PEX.
Thanks for your ideas!
-Chris
invertedflight is offline   Reply With Quote
Old 01-29-2008, 04:58 PM   #2
Send a message via AIM to Marlin
3/4 will be fine. You can run two fixtures off a 1/2in line. You could run two hot lines, one to the bathroom, and one that tees off for each kitchen or any combination that doesn't have more than two fixtures on your half inch line. I would recommend using 3/4, if waiting for hot water is a problem install a recirculating line.
Marlin is offline   Reply With Quote
Old 01-29-2008, 07:25 PM   #3
i second that marlin.
if your going to do add the recirculateing line. i will save money in the long run, haveing to wait for hot water
ranman469 is offline   Reply With Quote
Old 02-04-2008, 02:10 AM   #4
Thanks for the responses. Just to clarify, I am only supplying the full bath and kitchen on the 3rd floor, the kitchen on the second floor has been removed.
So you both reccomend that I do a 3/4" hot line instead of two 1/2" hot lines?
Thanks,
Chris
Old 02-04-2008, 10:27 PM   #5
I recommend a 3/4 line with a 1/2in re-circulating line.
Plenum/Duct sizing Manuel6 HVAC 8 03-28-2011 09:36 PM
LPG pipe sizing information steve1234 Plumbing 1 12-14-2007 11:18 PM
blue or red pipe for radiator supply amakarevic Plumbing 2 07-23-2007 09:57 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
