Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2009, 08:39 AM   #1
Supply lines
Does anyone sell odd length fleible water supply lines for toilets. I can find 12 15 and 20 inch. I would like to buy a 10 or 11 inch.
PiedmontNC is offline   Reply With Quote
Old 12-21-2009, 09:05 AM   #2
You are probably stuck with the 12". Should you ever need to disconnect and then reconnect the line, you may be glad you did.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-21-2009, 12:57 PM   #3
home depot ussually sells 9" lines, at least my local home depot does.
scotty123 is offline   Reply With Quote
Old 12-21-2009, 04:34 PM   #4
Rewards Points: 150
Most flex stool supplies are either 9 or 12" long
rudolph58 is offline   Reply With Quote
Old Oil Furnace Supply Lines tjeieio HVAC 2 08-10-2009 02:56 PM
Braided water supply lines - joining two KLR Plumbing 8 06-02-2009 03:53 PM
Crud in supply lines jenoble99 Plumbing 5 02-13-2009 12:08 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 04:23 PM
