Supply Line Valves Keep Shutting Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-01-2012, 12:18 AM   #1
This problem is more of a frustration and curiosity than a terrible problem. We moved into a modular home in 2011. While the house is well built, some of the items are not great. The valves on the supply lines to all of our sinks are some cheap plastic type that turn on by pushing them down and turn off by pulling them up. I don't know what they are called, but I put two pictures of them in this post.
Since things started cooling off in late August (we live at 7000 ft in Colorado right next to the mountains) the valves have been shutting themselves off at night when it cools off (Valve Pic 2 shows the right/cold water off and left/hot water on). This just started happening and was not like this the first winter in the house. Any ideas as to why this is happening?
Tom
Supply Line Valves Keep Shutting Off-valve-pic-1.jpg   Supply Line Valves Keep Shutting Off-valve-pic-2.jpg
tcharleschapman is offline   Reply With Quote
Old 11-01-2012, 08:20 AM   #2
Rewards Points: 3,130
Wow, looks like the sort of thing you'd find in a RV (lightweight and cheap). I'd just replace them with quarter-turn valves.
The Following User Says Thank You to md2lgyk For This Useful Post:
joecaption (11-01-2012)
Old 11-01-2012, 08:36 AM   #3
Rewards Points: 13,300
Replace it with two of these.
A 10 min. fix.
Shut the water off at the main, open the faucets to relieve the pressure, remove the old and slip on the new.
Fuzzy picture but it looks like you have the type valve that to remove you have to press in the gray ring to get it to reliece.
http://plumbing.hardwarestore.com/52...ve-667781.aspx
Old 11-01-2012, 01:01 PM   #4
when the water in the pipes cools off it contracts and is pulling the valves closed. the plastic valves are also contracting with the cold so the resistance is less to open and close them.
Old 11-01-2012, 03:05 PM   #5
DannyT: That is what I thought, but the valves pull to close. Is this still happening? It seems like expanding water would force them to shut, not contracting.
I've thought about replacing them, but some special tool is needed to get them off. They aren't the easy ones you find in the hardware store. What tool would I need cut the pipe to remove? Also, what can I do about the fact there isn't enough pipe left for my hot water to attach a new valve to after I cut it?
Old 11-01-2012, 03:43 PM   #6
There's no need to cut it, reread my post please.
No special tools needed, an adjustable wrench set to the pipe size works fine to push againt the gray ring to reliece it.
Old 11-11-2012, 02:09 PM   #7
joecaption: I've tried to take a better picture. These are two angles from beneath the same valve. Where is the mechanism to remove them?
When we moved in we got a new dishwasher from Home Depot. The group came in to install it and couldn't because they don't do anything with these types of valves. Something about insurance not covering. A separate install guy came out and had to cut the pipe off just short of the old valve and install the new one, which is the one you recommended.
Thanks.
Supply Line Valves Keep Shutting Off-valve-underside-1.jpg   Supply Line Valves Keep Shutting Off-valve-underside-2.jpg
Old 11-11-2012, 02:17 PM   #8
Deleted because post was a duplicate.
Old 11-11-2012, 04:33 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 452
I did a little search for you- and anyone else with these valves.
I have removed them before and I usually resort to brute strength and a pair of pliers- twisting and pulling...
This video shows a trick or two. His are installed on CPVC pipe
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (11-12-2012), tcharleschapman (11-12-2012)
Old 11-12-2012, 02:40 PM   #10
This is excellent! I didn't think I just needed to unscrew it. So, I now know I just need to pick up some new valves at the local hardware store. Is there any special way to purchase the hose, because that is not only permanently connected to the valve, but I'd like higher quality ones?
Old 11-12-2012, 05:59 PM   #11
Just buy stainless steel braided lines with a 3/8 end on them.
Old 07-17-2013, 05:42 PM   #12
Thanks everyone that helped!
I had delayed this for a while because I was afraid I would screw something up.
So, I tackled the two valves under my kitchen sink. One I had enough pipe just to cut off the old valve and install a new quarter-turn valve (one of those ones you just screw on and it clamps down on the end). The other not enough room to install a new valve so I tried unscrewing. While a HUGE pain to get it off, it did come off. Installed a valve there, too.
Since doing these two valves, no other cheap valves have popped in the house. I may try to do one sink a month to keep cost low.
Thanks!
The Following User Says Thank You to tcharleschapman For This Useful Post:
TheEplumber (07-17-2013)
leaking main supply line from street alpinekid Plumbing 0 07-07-2012 03:52 PM
Cold Refrigerant Line...Warm Supply camryman95 HVAC 7 06-30-2011 06:29 PM
Solenoid valves for water supply HankBrandenburg Plumbing 1 01-14-2009 10:47 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
