Supply Line Rough In Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2012, 06:40 PM   #1
Supply line rough in question
While doing some plumbing work on my tub I noticed they ran two hot and two cold supply lines. The connect at a 90 degree.
Is this normal I've never seen it, what is the purpose?
harlan07 is offline   Reply With Quote
Old 12-30-2012, 06:41 PM   #2
Old 12-30-2012, 06:52 PM   #3
Plumber & Gasfitter
Rewards Points: 77
If you are slab-on-grade, then those supply lines might be branching off back under the slab to pick up another fixture or two.
joeplumber85 is offline   Reply With Quote
Old 12-30-2012, 07:00 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 994
continuing supply loops flexible copper is used with no solder joints below the slab, all connections are soldered above the slab. as Joe P stated ..just added my two cents.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-30-2012, 07:01 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 568
Yep, appears to be a simple loop with a tee in it. You don't want joints under the slab so you loop up above the floor
Old 12-31-2012, 11:33 AM   #6
Thanks guys, appreciate the response.
Removing this type of supply line from bathroom faucet? dveiga Plumbing 5 04-24-2011 08:58 AM
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
Pipe size question for supply side... Alvis Plumbing 4 02-16-2011 04:57 PM
Bathroom sink supply line leak afarr Plumbing 6 05-26-2010 05:59 PM
dishwasher water supply line options kenm09 Plumbing 2 02-11-2010 08:17 PM
