-   -   Supply line rough in question (http://www.diychatroom.com/f7/supply-line-rough-question-167806/)
harlan07 12-30-2012 06:40 PM
While doing some plumbing work on my tub I noticed they ran two hot and two cold supply lines. The connect at a 90 degree.
Is this normal I've never seen it, what is the purpose?
harlan07 12-30-2012 06:41 PM
1 Attachment(s)
Attachment 62760
joeplumber85 12-30-2012 06:52 PM
If you are slab-on-grade, then those supply lines might be branching off back under the slab to pick up another fixture or two.
Javiles 12-30-2012 07:00 PM
continuing supply loops flexible copper is used with no solder joints below the slab, all connections are soldered above the slab. as Joe P stated ..just added my two cents.
TheEplumber 12-30-2012 07:01 PM
199 Attachment(s)
Yep, appears to be a simple loop with a tee in it. You don't want joints under the slab so you loop up above the floor
harlan07 12-31-2012 11:33 AM
Thanks guys, appreciate the response.
