Supply Line Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2013, 01:28 PM   #1
Rewards Points: 31
Supply Line question
Is there any restriction on using 90 degree elbows in a 3/4 inch copper supply line to get under a beam or joist to continue a run? I'm in Oregon
Outdoorbum is offline   Reply With Quote
Old 10-12-2013, 02:38 PM   #2
Rewards Points: 1,706
None I know of.
Old 10-12-2013, 03:13 PM   #3
Rewards Points: 12,882
Why not drill a hole and go through it?
Main reasons are it would reduce the restriction in the lines and if at some point someone was to finish that area it would be one less thing to have to work around.
jmon (10-12-2013)
Old 10-13-2013, 08:00 AM   #4
Rewards Points: 1,214
You can use wide sweep ells if need be.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-13-2013, 09:42 AM   #5
dannyoung85's Avatar
Long sweep ells are only used in refrigeration piping. You should be fine with a standard 3/4" ells.
dannyoung85 is offline   Reply With Quote
Old 10-13-2013, 10:01 AM   #6
Wide sweep ells are used primarily in HVAC but you can use them in plumbing if you need to decreased friction and limit pressure drop. You just have to size them correct because HVAC copper is sized different than plumbing copper.
I used to install computer room air handlers that used Glycol cooling coils , the specifications stated that wide sweep ells shall be used to limit pressure drop.
The Following User Says Thank You to COLDIRON For This Useful Post:
ben's plumbing (10-13-2013)
Old 10-13-2013, 10:11 AM   #7
By the way I am not saying he'll have a problem with 3/4 ell I am just giving him an option if he thinks there will be a problem. We actually don't know how many 90 ells are in the system. But as posted don't sound like a problem. I probably would have drilled a hole right through the joist as Joe recommended if possible.
Many diyers don't know there are wide sweep ells.
Old 10-14-2013, 02:03 PM   #8
Rewards Points: 31
Thanks for the replies. Yeah, I didn't know wide sweep L's were an option. I suppose I can drill as well as long as I'm not in the middle third of the joists. Was trying to avoid that if possible
Old 10-14-2013, 04:50 PM   #9
Rewards Points: 582
regular 90s long sweep 90s both ok I doubt if you would loose much pressure or volume to cause any major problems...ben sr
New Guy Here. Main water line question... Freestyler Plumbing 8 11-26-2012 08:59 AM
Removing this type of supply line from bathroom faucet? dveiga Plumbing 5 04-24-2011 09:58 AM
Water supply line blackhemi Plumbing 4 04-09-2011 09:18 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 12:26 PM
