Supply Or Drain? What First? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2010, 10:28 AM   #1
hohadcr's Avatar
Rewards Points: 338
supply or drain? what first?
im totally doing new plumbing rough-in in open walls. what should i run/install first? supply or drain? im using pex as supply.
hohadcr is offline   Reply With Quote
Old 03-13-2010, 10:31 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
drain is the larger and it has requirements as to slope and other things such as distance to a vent. As such, I believe you should design the drain first. The supply can be run where ever you have space left.
Old 03-13-2010, 11:07 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Correct. Much harder to run drains around water lines.
Journeyman Plumber
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
