Supplemental Water Heater ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2011, 03:47 PM   #1
Supplemental water heater ?
I'm installing a second floor full bathroom and am considering putting in an electric instantaneous water heater to ensure that I always have hot water for showers and possibly for the lav. There are two other full baths in the house. They are supplied by a 50 gallon electric water heater. The distance to the second floor bath isn't that great. Everything is in a central plumbing stack. But, I have three teenagers that go through hot water at light speed. I would just like to make certain that my wife and I can take a truly hot shower when we'd like.
Looking for advice about a reasonably priced point of use heater. Would prefer an instantaneous model. Looking for a reliable system. Have a 200 amp main panel, one 40 amp sub panel, and one 60 amp sub panel with open slots open. Our water supply is a private well system with a softener in place.
How large of a heater do I need? Any brand recommendations? Things I need to consider? Thanks for any input you can provide.
Sdebick is offline   Reply With Quote
Old 02-24-2011, 05:08 PM   #2
Rewards Points: 1,520
Why not two normal heaters plumbed in series (or parallel? Can't remember which is preferred.)? A point of use heater is typically for small quantities of hot water, not for a shower. They will not be able to keep up with a shower flow rate. Going electric instantaneous for the whole house is likely not worth it $ wise if it is even available.
bob22 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
